mike1180
Banned
I wanted to build my own wheel balancer and wanted it small (no room for storage), and accurate, and above all cheap.
This will be in 9 posts and then I hope the pics will stay.
Parts List:
1. 2 pcs - 1/4 X 2 inch angle aluminum 12 inches long ($5 scrap)
2. 4 pcs - Abec 9 (or lower if desired. It will work with less) Rollerblade bearings ($6 ebay or local skate or skateboard shop) If possible, buy the bearings with removable side plates so you can take off the side plates and wash out all the grease and just give them a small shot of light oil when you start to balance. Taking out the grease and adding the light oil lets them turn even easier. This is optional.
3. Existing OEM font and rear axles. (Don’t forget to use the 2 small collars on the rear when balancing.)
4. 10 pcs - #8 robertson screws 1 1/4 or 1 1/2 inch long. ($1)
Rollerblade bearings come with different sized center holes so adjust the bolts and washers accordingly:
5. 4 pcs - 5/16 by 1 1/4 inch bolts and nuts ($1.50)
6. 12 pcs - 5/16 inch washers ($1.50)
7. 1 pcs - straight 2X4 or 2X3 8 feet long - cut in half. ($4)
8. 600 grit sandpaper ($1)
Total: $20 (CDN)
Parts List:
Total: $20 (CDN)
