Got a PM asking about bearings. I'll post here for anyone interested.
Member wanted to buy OEM Busa wheel bearings. Needed them ASAP going on trip soon.
None on the shelf at Suzuki dealer.
No worries. Hit any place that sells bearings. Industrial supple house,etc. Whoa Rubb,dont I need OEM for my Busa? Yes and no.When you take out a "Suzuki" bearing,(or any bearing,Ford,Chevy,John Deer,etc) read the lip. Its made by somebody. Get 3 measurements. OD,ID and thickness.(some "parts dudes" don't like to get out their own micrometer,if they even have one) Take this info to the dude at the supply house. He'll come back in a minute and throw down on the counter yer much needed Suzuki OEM bearings. They are Toyo or Timken or whatever for your application.They might even be in the same box as the "OEM". Cool.They are in stock. More cool. Zook OEM $49.95 bearing house...12 bucks. Awesome right. More cool. What you took out of your project might have a bearing that is sealed one side,2 sides or not at all. Get the quality 2 sided. Less dirt gets in the bearing shortening its life span.
Now you've got yer new bearings and they are ready to go in. Not so fast. NEVER trust anybody's bearing to be ready to go. Yup,paranoid Rubb at it again.Whatever. Take yer new bearing,CAREFULLY remove both seals (I use my trusty tool box scapel) Look inside,see that low budget grease used in mass production...you want it gone. Clean with varsol or whatever. Dry the bearing. However tempting,do not use your compressed air on it,spinning it (dry) making that cool whirring noise. Blow it from the sides. Cool,out with old,in with the new. Won't get into what brand is best,do yer own research,1000 opinions. I like a brand thats MC specific and that has a anti grease monkey inner lid. Take off outer lid,inside a second lid with a hole in the middle.As you press down you get fresh contaminate free grease. Take said grease and force it into the bearing. DIY tricks can be used. Yer tool box syringe for instance. Anyway,force the grease in there with fingers or whatever. This will take time. I like to only go from 1 side at first,depending on bearing type you will see grease eventually come out the other side.(not applicable to all bearings). Grease in,satisfied,re-install seals. GTG.
Bearing removal and re-install. Proper pullers and hydrolic press prefered,but can be done without. Some DIY'ers dont have fancy equipment. Fancy puller=brass punch+hammer. Fancy press=old socket+hammer.
Removal...go slow. Treat the bearing like head bolts. Cross hatch pattern. Tap tap tap on one side,move to the other. Use your "jazz hands" very light taps,constantly changing location. This will take time. They will come out eventually. Sure,get bike shop to re/re.
Install...again,use your inner feminine touch. Grab a socket with the same diameter as the bearing.Place bearing in the hole. Tap ever so lightly to get it started. If it goes cok-eyed,yer doing it wrong. Sometimes its better to just tap around the edge,again,one side to the other,to get it started. Plastic mallet preferred,but not critical.Once you feel its started in straight,place yer socket on top and send 'er home. How far in? Till you feel it stop. It will feel different when striking and also the sound of your strikes will/may change.
Bearing on right,sealed both sides.
Grease...not all are created equal..buy good quality,NOT all purpose...like this...LOL. I like the toxic kind as opposed to the ones the "Flower Power" crowd uses.
Scapel. Very handy,multiple uses. I use this type.Change out many styles of blades and when they get dull...like me.
Also handy for when the job goes to shi7. You can use the thing to slit yer wrists.
Hopefully that helps you out. Stand by for flames and opinions...all are welcome,it's how we learn.
Rubb.
Rubb.
