Busa bogging out
stevenruss
I just changed spark plugs and it sounded perfect when i started it, it had starting bogging out about a week ago, but now its doing it again the very next day. i have good fuel and checked air filter and everything seems to check out good. when i give it throttle it seems to just slow down instead. please help.. much appreciated
What year and how many miles ? What did the plugs look like ?
It's an 01 with about 26000 and it's all stock. The plugs did look a little black, but nothing crazy. It almost feels like when I give it throttle, only 2 or 3 are firing up, if that makes sense
You have got good air and spark, try running some Seafaom thru it. You may have dirty or clogged injectors.
i did run seafoam through it with no help, so i just took the injectors out and cleaned them.. now the bike is running great!! thanks for all yalls help. are all busas' fuel injected?
I have same problem..idling at below 1000 rpm found the coil for cylinder 1 had a large cracked...changed it out now it wont stay on..it turns on with choke on but even with choke on it doesnt stay on..its a 2004 busa with 34,000 miles on it...i recently changed the plugs on it about 3 weeks ago...im lost as to what it is.
My guess was going to be you're not getting fuel for some reason.
Good job sorting that out!
