Busa Brake lines
madlyhs
I am planning to replace the Busa stock brake lines and I am wondering about which is the best replacement lines?
I have been looking at Stainless Steel braded Brake Lines & Kevlar Brake Lines; which one do you recommend and from where to get them?
TIA
<!--EDIT|madlyhs
Reason for Edit: None given...|1105807930 -->
Any of the top brands will work the same. From the prior discussions it doesn't seem the Kevlar lines would make any noticeable difference except in your pocket book. I got mine from HEL and they are great.
http://www.h-e-l.co.uk/
Either one will work just fine.
<!--EDIT|BA BUSA
Reason for Edit: None given...|1105859329 -->
you can get stainless goodridge lines on e-bay for about $90. I got mine at the local brake shop for $70 (my rear line is longer also for extended swingarm).
Check cyclebrakes.com SPECIALS
should have some of the best prices...
<!--EDIT|ks-waterbug
Reason for Edit: None given...|1105893954 -->
