RaveCrusader
I got some after market brake pads for my new Busa this week. All I can say is wow. I went with Galfer pads front and rear. I estimate that my stopping distance versus the stock pads is reduced, depending on the speed, from 33% to 50%. I picked them up at the local cycle gear here in Vegas. If you have not looked into it, I would advise doing so. The back brake is a little more difficult then changing out the two front brakes. I would advise at least doing the front brakes. They are easy and both sets of pads together are only about $60 total. I was able to change the brakes out on the front myself in less then 20 minutes.
GALFER SEMI-METALLIC BRAKE PADS
Front: 156 (x2)
Rear: 111
http://www.cyclegear.com/spgm.cf....013SM_G
Just a thought...
Front: 156 (x2)
Rear: 111
Just a thought...
