busa disassembly
hayabusa_83
hey guys, im tearing the bus down, to paint/prep it, and running into some problems, as for the tail, i cant figure out how to take off those 4 metal "things" that u use for like a tie-down, on the rear... and if someone could please explain how to easily remove the front end.....any help would be appreciated...thanx
Pop the little black caps off with a knife blade and that will reveal a allen head inside. have fun.
What he ^ said
Only the front 2 are screwed to the frame and actually hold the rear plastics.  The back 2 are screwd into the grab rail, which is held in by 4 bolts...12mm heads I think.
Yeah, what they said about the black plastic plugs.  5mm Allen fits them.
I know I'm a bit late...should have looked at the date !!!
BTW, What part of FL are you located?
<!--EDIT|flynjay
Reason for Edit: None given...|1138080362 -->
