Should be pics of mine in the Drag Racing section but....
Put the release clip on the right side(sitting on the bike). Run the strap up and over the neck of the frame(between the steering neck and 2-gas tank bolts).
Also, MAKE SURE YOU RUN THE STRAP UNDER ALL THE LINES! DO NOT YANK IT DOWN OVER THE LINES THAT RUN DOWN THE FRAME ON BOTH SIDES! Also when you yank it down, make sure you have even movement side to side(turning back and forth). If it's binding up release the strap, straighten it and then yank it down again. (NO BINDING or it can cause you to crash from a tank slapper!)
P.S. I would have ran it bone stock first to see what the bike will do. A bike is totally different on the track then on the street! You need practice launching it smooth before you launch it hard....IMO! Same with the tire pressure. If you haven't raced before, you don't need to be messing with that stuff now. Get some seat time then try and go faster.
Or have you been before?
