busa hard to start
Velloz
i had problem with my busa,it was the battery,i got a new one,and now after i charger it,it start,and wnen i turned it off, i can t start it again,i am going crazy.it s fully charged,but don t start . Help me pls.
Guys need to learn when you want help you need to give us a little more specific information. Alot of guys won't bother to answer your post when you don't give us anything to go on........we need more, like what was it doing before the new battery to make you replace it, whats it doing now, yeart of bike, mileage ect. You may not have a battery prob at all, then again you might...but it could also be a starter prob, heat related.....fuel issues...electrical...the list goes on. Give us a little more info
Need info regarding the symptoms. Have you had other problems? Is the bike new to you? Type of battery? Are you 100% certain the problem was the battery?
Can't really help you without knowing more.
The bike start i ride for 15 20 minutes and i cant start again, i had something like that before it was a starter, but it s brandnew, i don t understand,i have this busa for a few years now. Looks like the battery s ok, but dosent crank if isnt fully charged.
Thanks all
Check your charging system. It might be that your alternator isn't putting out, or your regulator/rectifier is not working. Check your battery cables, as well.
