Busa has a wiggle ?
johnstein
recently i changed all bodywork , rims amd tires . after the switch i noticed a wiggle after 100mph , up until then its fine , i have almost 22000 miles on the bike so i am pretty familiar with how its supposed to ride , i did change over to pilot powers are they less stable at higher speeds than the stock battleaxe ? balancing problem ? or did i screw somthin up during the swap,
rear rim has two spacers , musroom shaped spacer toward the brake caliper
front wheel , if sombody could take a look at thier bike it would help , i have 2 spacers installed on either side of the rim it kinda looks like the fork is spreading at the wheel , maybe i am supposed to only have one spacer up front ?
basicaly i am second guessing myself , bike has been handeling fine except for the over 100 wiggle ? maybe its just the pilot powers ?
It's not the pilots... did you make sure the tires are on in the right direction? (as in that other post I saw about mounting tires)
yep , i been through just about everything , in the service manual it shows 1 spacer on the front wheel i have 2 one on either side ?
it could be in my head
Rebalance your tires and make sure you leave the valve caps on when you do.
--Wag--
You might also check steering bearing play, front rotors for warping and re-torque your axle pinch bolts, axle bolt etc:
runeight
