busa has no eletrical power
almore
Hi, i was on my way to work and my busa cut off . now it has no eletrical power at all. wire hardness has been replace and that is not the problem, what a waste of money. it was said that a ground wire is loose or not conneted somewhere on my bike. my busa still with out power and dont know what to do. no power on dashboard or anywhere on bike, also has new batt. Do anyone have any ideal.???
Why was the harness replaced? What year is the bike? Some bikes may have a problem with the regulator-rectifier.
Main 30 amp fuse at the starter relay!
If your bike is blowing the main fuse, while the bike is running, it sound like a heat related problem with the stator!
It could have short, as the heat cause's expansion!
