LiBusa
I'm reviewing my options for engine oil filters. I presently us the ML filter from purolator which costs me about half the price of a OEM filter. I understand that the filter I use is not a good filter. As a matter of conversation it appears that all the available filters including the factory one are not that good at filtering.
The recommended filter is the Purolator Pure One which has different threading which can be used by installing a different treaded fitting. Also the filter is taller which means that maybe some tube/plumbing may be in the way. According to Pulolator the pure one filter is to large for motorcyle oil pumps. Has any one done this filter Mod and if so does it work properly. Below is the site for the oil fitting adpter:
Bales Technical Service Oil Filter Adaptor
Regards,
Lionel
Regards,
Lionel
