I have stripped my oil pan out, wat would be the best way about going to fixing it?? I see new oil pans on ebay cheap. I just dont know if its alot of stuff to change and how hard is it? Thanks alot guys
helicoil will fixit better than new for under 20 bucks , and you can get everything you need at a local autoparts store. bring the drain plug and they will hook you up.
(johnstein @ Mar. 11 2007,20:32) helicoil will fixit better than new for under 20 bucks , and you can get everything you need at a local autoparts store. bring the drain plug and they will hook you up.
+1 NAPA will have it all for a couple of bucks..
If you do take the pan off its pretty easy, theres an oil cooler fitting on it{2 allen bolts} and a radiator bracket{2 more allen bolts}, if the gasket rips grey silicone it.. And watch where the bolts come out some are different sizes...
But I have installed helis with out taking the pans off {most dont take them apart}....
Good luck....
My dad and I used these quite often when I was younger and getting started in building/rebuilding old Harley engines. They are steel thread inserts and actually get flared into the drilled out hole. They work much better than Helicoils.
