Busa powered funny car
Mytcar34
Mini pro funny car 1999 busa powered. just pulled car out of storage car will run if you pour some gas in the fuel injection then engine dies when it runs out of fuel. fuel pump comes on and builds pressure. I am not using a busa ignition switch I wired in a resistor I think a 200 0hm. I think this is my problem but not sure I just replaced the resistor with a 220 ohm but no luck any ideas???
depending on length of time in storage injectors could be seated.. open throttle body and try to crank. injector should squirt fuel...we have them if needed..
1/4 watt 100 ohm
