Busa starting only on 2 cyl
Tajammul Khan
I am a new busa owner which turned out to be a expensive affair:) bought a 4yrs stationed vehicle on a side stand then cleaned all necessary things like fuel drain and pump cleaning to plugs change then it fired and idling isn't standing also sounds different so checked with single plug start and 1 and 2 individually the bike started but on 3 and 4th plug it didn't fire so on stationed plug the spark is on all 4 but on 1&2 have got dirt but 3&4 is like what I installed no Corbon or wet, also noticed after some ripping with the same status right hand exhaust turned hot like red inside the pipe but the left didn't turned so like the other, kindly help me what I need to check with my bike start like normal, I am from India and have limited resources like metres or other equipment to check so it's should be all manually working suggestions., thanks in advance
