When strapping the busa down, you need to make sure the straps do not rub on the plastics or it will wear the paint off. I have a Baxley chock and they work great and do not need any straps on the front, just the rear pulling toward the front and down. They are worth the $$. You can use the Baxley in your truck without mounting it to the bed. If you need to strap down the front, a good way is to go to the lower triple tree with a short loop, and angle down between the front fender and the nose.
