Issue: Bike won't turn over. Fuel fuse blows every time I attempt to start the bike
2007 Busa sat in garage a year and was not winterized. It had a half tank of gas in it before it was stored. New plugs, oil and battery but the bike still won't turn over. Removed old gas removed fuel pump from the tank and cleaned the housing around the fuel pump. Sticky substance around the housing.. Bike turn over but won't start, fuel fuse blow.
Note: Starter fluid will start the bike and cut off when the fuel is burned off. I'm thinking the fuel pump is could be clogged or bad. Could a clogged or bad fuel pump blow the fuel fuse?
