Alright guys and/or gals, thanks a lot for the quick Busa-like responses. I haven't personally owned or ridden a bike that had any transmission shifting problems so this would be a new feeling to experience altogether. When I go and test drive a Busa, how "hard" do I have to push/test ride it to produce the problem if it exists? I believe I can tell if the bike didn't feel smooth or normal shifting between gears but if the bike did have a problem with slipping out of gear, would it happen during gentle/normal riding or during heavier load?
You need to push it hard to discover if you have the second gear problem or not.
I mean wide open throttle , because it can hide itself otherwise.
I am talking from experience because it has happened to me.
It's a little hard to describe but I shall try.
1st and foremost don't look for it right off the bat when test riding your prospective Busa, why do I say this ?
Because you must warm up the tires first ,otherwise you could be that guy, who spins up the rear and dumps the bike.
So after a reasonable amount of miles lets say 10 .
Stop the bike in a safe place. Make it on a straightaway also.
So now your going to launch it as you would in a drag race.
Click into 1st ,release the clutch, wide open throttle to about 6k in 1st, nice firm shift into second, right back into wide open throttle, this is where you will discover if it has the " problem "or not.
The tranny will either hold and you will shift into 3rd and let off, or it will " Pop " in and out of gear.
It makes a horrible grinding noise and you and the bike get jerked forward and backward as it pops in and out under load.
