Max
Well the Suzuki manual code indicates: error C-25 = "Ignition cylinder #2- coil/wire connection/ or battery supply problem?" The bike revs to 8k rpm under load then power fades and gets an "F1 light-C-25 code". I replaced battery cables..battery..#2 coil..rectifier.. checked every wire, connector. Removed cable kill switch and still wont run right. I also noticed its popping under hard deceleration now..like lack of fuel? Will check the fuel filter in the a.m. I did a leak down and the motor has around 2% on all 4 so Im hoping the motor is okay.
Any advice would be GREATLY appreciated. Thanks guys.
I should add ..Today the code changed from C-25 to 'C-25+C-26'..then changed from C-25 to only C-26 now later in the day. Im scratchin my head on this one.
