santomotion
Hello everyone,
Here is what it happens with my busa, it's a bit weird to me, I hope the knowledge it this forum can guide me a bit.
The bike was running "OK", it did hesitate a bit around 3000rpm plus it had some noise that looked like it could come from the chain.
After doing a bit of research I found out the Gen 1, specially the 1999 (mine), model had some issues with the Cam Cain Tensioner (CCT).
I did replace the CCT for a newer one from a Gen 1 2007 model. My bike didn't have the oil pipe that connects at the top of the CCT, I don't know if that came from the beginning (1999).
The bike now doesn't run properly anymore. Actually it can't rev up, as soon as I open any throttle the revs fall. It almost looks as if the cam chain had jumped one or two teeth and now there was some kind of offset with the valves timing (not enough to make the valves hit the pistons but enough to make the engine run horribly wrong).
I've tried a few thinks like checking all the vacuum pipes, checking injectors and plugs are all plugged correctly, valancing the throttle bodies, adjusting the Throttle Position Sensor (TPS)... but it still runs badly.
In this two videos you can see how the engine dies when some throttle is applied. There are also some detonations out of place, you can see them in cylinders 1 and 2
On this one you can see how if the engine goes over 4000rpm then it's easier to hold the revs up
The last option is going to be removing the engine and opening it to check the cam chain
Any comments will be very much appreciate. If you need any more info, pictures or videos I will happily provide them
Cheers!
Cheers!
