Hi All,
I replaced the cam chain on my 2000 'busa about a year ago and it began making a high-pitched, very loud, screeching noise above 4500 RPM...below that, no noise at all. It doesn't increase in decibels and likewise doesn't go away at higher RPMs. It's like flipping a switch...it appears at about 4500 and stays there until the RPMs drop below that. It makes the sound when idling or under load. It runs fine but it's embarrassing to drive so I parked it until now, and now that it's summer I want to get it rolling again. It sounds like it's coming from the top of the motor on the cam chain side. Do you think the top cam chain guide might be bad? Not sure if a bad guide would cause that type of sound, but it didn't make the sound prior to replacement.
I replaced it because the old chain was too loose. The tensioner was at full extension and the chain was making a rattling noise, but nothing as loud as the screech it's making now. I got the new chain from Competition Cams so it should be a quality product. Tensioner is hydraulic.
