I had my 06 Busa in for its first service today ( 600 mile ). About a week ago a buddy of mine and I were talking about RPM's on different bikes and I was screwing around, and reved the crap out of the engine at idle ( 10000 or so ). I went for a ride a few minutes later and noticed a clacking noise from the engine. It is only noticable up until about 4000 RPM and it is not valve a valve. If you crack the throttle very slightly, slowly bringing up the RPM, the engine goes up but the frequency of the noise stays the same. If you give it any amount of throttle above that the noise goes away. The dealer listened to it for quite a while, even with a stethiscope thingy?? and advised that it was the cam chain tensioner. They said that sometimes the ratchet in the mechinism gets stuck. Sometimes you can get it to go away by reving the engine up and then slamming the throttle closed. Someone else tells me that the tensioner in the Busa is hydrolic and this will not work. The noise is less now but still there. I know that Busa motors are noisy, top end mostly, and mine was no exception. But this came on suddenly and is too much. To to it all of driving home I heard somthing new, I think with the clutch, but i'll save that for another post...
The gave me the good ol, "ride it, and if it's still there when you come in for the 4000 mile service, we will replace to part."
Any thoughts or ideas from those more mechanically inclined than myself?
