Cam timing_Busa_2000. Year
Gixer
Hy,
Which is the most better setup cam shaft in degrees
(I use the spacer 0.80 ", boost will be about 21 PSI, Garrett T34 turbo,..)?
Thanks
Thanks
This is the stock setup (I have not yet measured on my Busa ) ?
Another question, how did you solve the problem of displacement angle of the camshaft mounting spacer?
Thanks
slotted adjustable cam sprockets (ape raceparts)
