cams question?
LeDauz
ok. I know doing your cams will give you more power but what exactly does doing your cams consist of? is it just changing the cam sprockes or does it include your crank shaft?
You can have your cams degreed, that's stock cams with adjustable sprockets or...go with bigger cams which increase the duration of the opening and closing of your valves and they are degreed as well. Cam degreeing is not hard but you have to be exact with everything or the entire process can get messed up and worse...valve bending mess.
From Web's website!
WHAT IS DEGREEING IN YOUR CAMSHAFT?
Degreeing in your camshaft means synchronizing the camshaft's position with the crankshaft. A few degrees of misalignment can affect the engine's operation dramatically. If there were no manufacturing tolerances, you would only need to line up the marks on the timing chain sprockets and the cam would be degreed, but with a group of components (the camshaft, crankshaft, timing chain, and sprockets) all with their own standards and tolerances that when installed, can stack up against you. You can never be sure that the cam is in its correct position until you degree it in. For best performance, you should degree in all performance camshafts.
The basic tools required are a degree wheel, a stable pointer that can be mounted to the engine, a dial indicator with at least one inch of travel in .001" increments, a stand that mounts it to the engine, and a positive stop device to locate TDC.
Web-Cam offers a complete cam degreeing kit, see below for part number information or call for more information.
If you change your timing belt or chain, chain tensioner, cut your head, or deck your block, you must degree in your cams.
I've heard of guys swapping the intake and exhaust cams around and gaining considerable power. hopefully some1 will pipe in behind me and confirm this. i don't know much info on it tho, sorry
yes, some have thrown an exhaust cam on the intake side of things degreed them in and have had measurable improvements.
So if you were to change the cams to the best ones out there, in an otherwise stock motor, and degree them in, what could you reasonably expect in horsepower gain?
i really have no clue but I'll take an educated guess 8-12 hp
from cams alone....I think thats a little high. Especially with a low compression stock piston. Add some drop in high compression pistons....things get better.
