I posted, in the General Discussion Forum- "More R&D with Frank", specs for the stock Busa cam and a few aftermarket ones.
Interesting posts in that thread as well.
But, I thought it would make sense to put it here too for future ease of reference and then additional grinds, as they come available can be added without 50 posts to go through.
All DURATIONS LISTED BELOW ARE AT .040"
Cam----Int dur.--lift--Exh. dur.--lift-LC's
Stock--240 deg--.345"--220 deg.--.294"-106/99
Yosh stg. 1
-------244 deg--.354"--230 deg--.307"-102/105
Web 536/577
-------250 deg--.378"--234 deg--.330"-112/109
Web 483/536
-------250 deg--.395"--250 deg--.378"-106/108
ALL THE ABOVE DURATIONS ARE AT .040" LIFT
$540 for the Web Cams, cores needed, no sprockets incl. for this price.
$700 for the Yosh, sprockets included., no core req'd.
Web claims some customers have obtained 200-205 hp using 2mm&3mm overbore(higher compression 13:1 and up). Still early though and more infor will come. No info. back on a stock bore motors, which is my interest.
Yosh claims 8-10 hp gain with stock pistons/pipe/remap, and have some cust's claiming 12hp.
Yosh is also offering connecting rods at $225 each for higher rpm and strength. Did not ask much more about them though, like their weight. I won't be changing rods anytime soon.
Looks like the Yosh and web 536577 may be good for stock bore/piston/head combo's with exhaust/remap/airbox. The other Web for serious big bore power and additional mods(head/valve work).
More info. on duration at different lifts is in the other post as mentioned above.
If other cams exist please post specs., and better yet--If you swapped cams, please provide feed back on what was done to the motor and bike and what was gained.
Looks like Suzuki left some room for the 1299 cc powerplant to strech her wings.
Bob
Yosh stg. 1
Web 536/577
Web 483/536
Bob
