Can It Be Done????
bacharles
Korrup~shun!!
I know that I will probably get ripped to pieces on this one, but here goes. Is it possible to mount the mirrors from a ZX12 on a Busa without much, if any, modification?
I've always wondered this, but never had the balls to ask... especially here.
I have always been very fond of the mirrors on a ZX12, but that's about it. Any help would be greatly appreciated.
(bacharles @ Feb. 19 2007,16:46) I know that I will probably get ripped to pieces on this one, but here goes.  Is it possible to mount the mirrors from a ZX12 on a Busa without much, if any, modification?
Have no fear I wont let you down,
Dont do it any part of a cow mounted to the Busa will slow the Busa down!!!!!
anything's possible. Someone with machinst skills can make an adaptor/spacer plate.
More the likely holes wont match. But if there the ones you like go to your local dealer and measure the distance between the bolts and match it to yours . Never know till you try . but of you do use them your gonna loose about 5 hp because there from the enemy.
(05BusaLe @ Feb. 19 2007,14:34)
<embed src="http://plugin.smileycentral.com/http%253A%252F%252Fsmileys.smileycentral.com%252Fcat%252FF%252Ftransport.swf%253Fcode%253DF%252F0%252F240%2526partner%253DZSzeb110%255FZNxmk572MAUS/transport.swf" loop="false" quality="best" bgcolor="#ffffff" width="100" height="120" name="transport" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" wmode="transparent" flashvars="code=F/0/240&partner=ZSzeb110_ZNxmk572MAUS" />
