Cut out problem:
After talking with the Suzuki tech rep for an hour or so (at my local dealer), here is what they might say, if Suzuki would officially put something out in print about this problem.
The fuel filters on the Hayabusa are *very* fine, gas additives, not fuel tank cleaner/coating, are causing buildup withing the filters (brown stuff), as pressure builds up in the system and reaches over 43 psi, the ECM shuts off igition to the bike. Simple thing here. I think he also said there was a similar thing for under pressure, but I don't remember what that evel was.
The fix is to install larger fuel deliver stuff (tech bull 108 & 109) on certain serial number ranges. Or I guess we could all starting using better fuel....
