card16969
So i just did an oil change with filter and put in 3500 ml of spectro (was in a bind and had access to it) and it still didnt register in the window so i added another 300ml and it brought it up around full so i took it out for a couple rides and have noticed i cant clutchless shift while just cruising down the road and noticed a bit of a humm at 5k rpm's. So i check the oil level after warming up the bike and its below the full line... wondering if i should add some more oil to bring it up to full and if it will take care of the problems, not sure if this is a common problem with the busa's or not.
Also i changed the tires and adjusted the chain but chain is to spec and tires are balanced (did them myself and i went to MMI in Phoenix and actually know what im doing)
