can't go back to fossil oil
1127 TO 1299
the title says it all,
why couldn't you go back to regular oil after using synthetic.
I use to mix then in my old gixxer 1100, never caused me problems and got rid of the bike at 75,000 km
I just tried Semi synthetic for the first time in my Busa...So I will let you know in a couple weeks.
Because regular 10w40 motorcycle oil does the job just fine. Ive changed my oil 3 times in the first 2000 miles and plan on changing it every 2000 miles from now on. Even in a high performance engine like the Busa there is no way the oil will lose any of its molecular properties/break-down or lose any viscosity in 2000 miles.
I believe that and that is why I intend to go back to regular oil. But what stops me is that I have heard many time that once you go to synthec you can't go back to regular. Could there be chemical reaction between the two?
Valvoline has an excellent motorcycle oil out... I use it or Kawasaki's brand oil.
Full synthetic molecules are all perfectly round, like ball-bearings. Dino oil molecules are shaped like tiny rocks with irregular shapes and jagged edges. Over time, they are actually abrasive. Then there's the temp thing. Semi-synthetics are a waste of money, just good marketing, IMHO. Go all out, or just stick with dino. Whatever you do, change your oil often! As for changing back, don't see any reason why you couldn't. If you mix synthetic and dino you wind up with semi-synthetic.
<!--EDIT|bronc3
Reason for Edit: None given...|1116056232 -->
A few good pionts on synthetic oils they do things better than an average oil. They will reduce wear, resist oxidation, have less volatility, leave fewer deposits, provide a more stable viscosity (thin out less at high temperatures and thicken less at low temperatures), Synthetic oil lasts two to five times longer than conventional oil; thus, waste oil generation can be reduced two to five times if synthetic oil is used. Synthetic oils have high resistance to changes in viscosity due to temperature. As a result, they provide a heavier, more stable protective oil film for engine bearings and piston rings than is provided by similar SAE-grade mineral oils. Synthetic oil permits better performance and longer endurance. synthetic oil yields better fuel economy, reductions in friction and wear, decreased oil consumption, improved performance, and extended drain intervals.Although some synthetic compounds are not compatible with conventional oils, adding a quart of synthetic oil to conventional oil produces a compatible mixture. However, the lower friction resulting from the use of synthetic lubricants makes them unsuitable for break-in.
The synthesized hydrocarbons, polyalphaolefins, diesters and other materials that form the base stocks of high-quality, name-brand synthetics are fully compatible with petroleum oils. In the old days, some companies used ingredients that were not compatible. As a result, manufacturers of quality synthetic lubricants were tarred with the same brush. Fortunately, those days are long gone.
Compatibility is something to keep in mind, however, whether using petroleum oils or synthetics. It is usually best to use the same oil for topping off the oil you have been running in an engine. It is preferable not to mix your oils, because the functions of additives blended for specific characteristics can be offset when oils with different additive packages are put together. For optimal performance, it is better to use the same oil throughout.
