Looks good, just waiting for the opportunity to use it.
Have a question though after doing a mock-up on the install.
The inside diameter of the bar sleeve is much larger than the Busa grip. When you pull down on the strap, the slop between the sleeve and the grip pinches the sleeve inward causing the tie down strap to move in towards the cowl. Curious if anyone has come up with a way to fill in the void between the sleeve and grip. I think this could move the tie down strap out from the cowl by an inch or better.
Thanks for any suggestions
Bill
ImageShack Links Do Not Work
Bill
