Carpenter Clutch Cushion ??
KenF
I understand the Carpenter clutch cushion kit is just the OEM friction plate the spring plate or ring that Suzuki put in the ’02 and newer busas.
Has anyone tried upgrading a pre 02 clutch with these parts and did it solve the “clutch grab problemâ€￾ .
Did you upgrade the springs at the same time.
Has anyone replaced a ‘02+ OEM cushion with a Brock cushion which makes it the same as an 01 with their cushion. If so, did the Brock cushion work better than the Suzuki one. And why do you think it does?
I used the 02+up Suzuki clutch mod, and it worked for a while, prolly about 100 passes, but it's getting sh!tty again. I'm considering trying Brock's next but I'd hate to pay $120 more for the same results......
If you want the hookup call me,i'll have you 60 footing like a pro.Daniel 503-786-1407
