CDI Triple-Levers Hitting The Farring!
Sweeney
Anyone experienced this with the CDI Triple Clamp?:
My levers are now hitting the farring insert at full rack left & right. Just barely pushing into the farring by 1/4", but it's enough to apply the brake!
I have adjusted the levers as close to the bar as poss. #5.
Should I just notch the plastic at this point or am I missing something?
Here's another angle
That is absolutely terrible... Send them back!
I'm pretty sure they are a sponsor here, and I'm not saying this to be an azz, but that is no good IMHO...
It's not a huge deal to trim the plastic if necessary. I am wondering if anyone else has the issue or if I'm missing something. (CDI's were not supposed to hit the farrings)
I beleive it's a quality product & looks great otherwise!
Waiting on some feedback before I butcher...........
It is hard to tell from the pictures. Can you rotate them a few degrees and get some more clearance?
They don't hit the fairings, you just need to adjust the angle of the levers/master cyl assembly.. it doesn't take much, but they don't hit if you just angle it up or down a little. Let me know what happens after you try this.
I wouldn't even worry about it. They will never hit when you are riding and if you are going lock-to-lock on the street you have more problems then the levers hitting. It can be a pain in the rear when moving the bike around but I haven't found a single company that doesn't hit unless you get a complete triple tree/clip on setup which is even more $,$$$.
Just be careful when moving the bike with the steering lock-to-lock...
I made alot of prototypes and spent extra time on these to solve this problem. Another small adjustment you can make it so slide the lever/Masters out towards the end more..spend a little time making adjustments to get what u want.
YOU ARE CORRECT! She's now Perfect! There's a pretty narrow sweet spot where they fit right in. Top photo shows where I was & bottom is slight adjustment.
THANK YOU for the direction! & a Great product!
"Glad I didn't do any bashing" This thing looks even better in person. The Black goes really good with the blue.
Not to mention the 1" drop I now have.
Thanks CDI!
Yup, I gots my head looking toward the ground now for saying to send it back. Apology for flapping my gums soo quick. The way it looked, was not good. I should have known better. I have seen a lot of your quality stuff. I know how excited you were to get these out in the market...
Glad you got it working!
Looks like CDiPrecision is where I'll be buying my next Triple Tree for sure now...
I had a heck of a time with past TT setups doing this so glad his works...
We may also make some for Gen 1, I didn't have time in this last run. I am also tooling up for Busa Quick access clutch covers..:)
