Amen to that. I installed 1 on my 07 and loved it. I can 2nd all the info above, except I will say it was a little bit of a pain to install because you have to virtually remove the whole exhaust to get access. I eventually loosened everything to the point where I could slide that last bolt in, but if I was doing it again I think I would remove the exhaust.I had one on my '06. Easy to install and no clearance problems at all. Wish they made them for my '08. Pain to oil chain on long touring rides.
The hardest part was installing the springs, if you have a good spring puller it is not an issue. You have to remove the rear under cowl, and leave it off.
I wish Suzuki could have made it available on the Gen 2. Nice feature but I have learned to work around it. Use a quick stand when away from home and pittbull at home.
Yep, springs this size are a b1tch, and can be dangerous to play with.
Old mechanic's tip: To install a big spring like the one on your center stand, get a stack of nickels and force them one by one in between the loops of the spring until the spring is expanded and slips on easily. Once installed, it's easy to get the nickels back out. Pennies work too, but are thinner than nickels and sometimes won't stretch the spring long enough for an easy install.
Hope this helps someone. - Cheers, AJ
Works even better if you ever have to remove the stand - you can slip the nickels in while the spring is stretched. Makes reinstalling the spring a piece of cake!GREAT tip! Never thought of that--THANKS!
i want a center stand, since it'd be more stable than the stock kickstand lowered like it is, but i don't want to lose the wing, lol.
