All righty... I used the product (self-gasket maker) and the rag method adn I can't find any leaks anywhere. I also returned the bike back to pre-centerstand setup and it is still making the same noise. I think I am stuck having to bring it to the dealer. Can anyone think of ANYTHING else that could be making the noise? Thanks everyone
Thanks for the info on the center stand. Think I'll be ordering one soon, just wish the bottom wing didn't have to come off.
As Atticdog mentioned, get new gaskets. Ronayers is awesome, but if they don't have them in stock you're looking at nearly two weeks of no riding.
I've never had the exhaust apart on my Busa but any other vehicle I've owned has required new gaskets or donut packings after removing the headers or manifolds.
A leak at the rear where the muffler pipes attach most likely would NOT cause a ticking sound.
Also I don't know of anything that comes out of a tube that will withstand the temperatures at a header pipe. Odds are the stuff dried up into a crust as soon as the engine came up to temperature and made things worse. There is a spray on copper coating that I usually put on new manifold and head gaskets, but it won't help a used damaged gasket.
Have you been able to pinpoint exactly where the ticking is coming from? You can always take a dowel rod or cut down an old broomstick, stick one end to your ear and the other end to various spots on the engine until you pinpoint the problem area.
Like I said I've never had the exhaust apart on my Busa, but if the gaskets are dead soft copper you can try to anneal them by heating them up cherry red with a torch and then immediately quenching them in cool water. Be careful not to bend them right after the process.
If you have fiber type gaskets ignore the above
Good luck!
