The Oracle
If you are like me (barely know the difference between a box wrench and a mitre saw)... Than this post may help you to adjust your chain slack.
The Motorcycle Owner's Manula (MOM) tells us that the tension should be set between 20 - 30mm (0.8 - 1.2 in) of slack. To measure this, the bike should be on its kickstand (since the value will vary if it is upright, on a rear stand, etc.). I use a simple and cheap caliper (that displays millimeters) to check my slack. Until you are used to it, eyeballing this setting may prove to be WAY off (as I found out).
1. Remove the cotter pin and loosen the axle nut. The axle nut is 36mm.
2. Loosen the lock nuts on both sides of the tire. They are 12mm.
3. Turn both adjuster bolts (there is one on each side of the bike) to adjust the chains slack. You will find that you don't have to adjust these very far to change the tension a good bit. Make sure you use the reference marks to make both sides even. The adjuster bolts are 10mm.
4. Tighten both lock nuts.
5. Tighten the axle nut with a torque wrench set at 100 Nm (10 kgf-m or 72.5 ft-lb).
9. Re-check the chain slack and make sure it is set properly.
10. Replace the cotter pin.
11. Grab a beer and celebrate!
Everything that is underlined above is shown in the attached detail picture.
Please let me know if you do this a different way, I missed something, or anything is on your mind.
Cheers, Vaughn.
Cheers, Vaughn.
