O Holy P
Rode the bike home from work tonight, it's about a 15 minute ride on the highway. I was doing 80~90mph, then off onto surface streets for about 2 miles and to the house. Parked it outside the garage for a few minutes then went out to roll it inside. When I was backing it up I could hear a very faint popping (for lack of better word), didn't sound terrible, but never heard it before. I put it on the rear stand and rotated the wheel and could hear that every time a chain barrel went into the sprocket trough that is when the noise occurred. And it seems to be only on the rear sprocket where the noise is coming from.
I checked the length from pitch 1 to 21 and it's under 12.5" so it's not stretched out. I also checked the sag and it's right at about .8~1" adding up & down together. So the tension is about perfect. Bike just rolled over 11,100 miles. I hit the chain with lube every 2~500 miles and clean it about once a month or 2. Just curious if anyone else had a similar experience.
Only thing I haven't checked is the tensioner block measurements. I had a buddy make a chain tension adjustment about 3 weeks ago because it was on the loose side and I didn't have the big socket for the axle nut. Goin' out to the garage to check that now.
