chain, sprocket, and air shifter question?
FTMFW
2008 busa, going to be stretched about 7", 310 lb (unsuited) rider, looking for a little extra at the track/street, but i still cruise everywhere, what should i use for sprockets?
where can i find a BLACK 160 link chain? i also want extra master links :)
i want to air/c02 shift. whos had good luck with what setup?
I'd go with a Pingel electric shifter, up 2 teeth in the rear. That's what I have....:laugh: works great for a 330 lb'er with a 4'' stretch
EK chain.....Im 9 over and a 150pin works for me. Run a steel sprocket if your doing the drag track and atleat a 43t rear.
Cycletek for the shifter...best Co2 out there.
Get the zzz chain with steel sprocket and Cycletek Co2 shifter. I am 380lbs(geared up) for drag racing. Bike is an 08 with 6" stretch , Cycletek air ****er, and for sprockets gearing is 16t front and a 47t in the rear. For drag racing I would also recommend getting Brocks frontend strap kit.
