winlite
I have only seen a couple of posts using search that address the problem of chain tension changeing as sprocket rotates. I am getting about an inch more deflection in the chain at the loosest point of rotation. The rear cush, or sprocket drum, looks like it may have 3/16 in of runout at the point nearest the swing arm on the left side. This may not mean a thing as it relates to the overall accuracy of the rear cush drive. My question is what is the most probable cause , cush drive , sprocket , or chain? Nothing feels wrong when riding the bike. Is it normal to get a small amount of different tension when rotating the tire or should it be exactly the same through 360 degrees of rotation? All help greatly appreciated.
