M Mad` Registered Nov 10, 2005 #1 I'm getting a 4" extended swingarm. What chain do I need to handle 300 HP and how many links? Thanks, Mad`
S StreetnTrack Donating Member Registered Nov 10, 2005 #2 Either go with the EK ZVX or the EK ZZZ what size sprockets are you going to run. You will probably need 150 links and then cut to your exact set up.
Johnnycheese Registered Nov 11, 2005 #4 (Bigger-Busa @ Nov. 10 2005 said: jack-shaft 10" over Click to expand... SWEEEEET
