Chain ?
busa1300nut
Local dealer only has a Regina Z ring in stock, and I need one NOW. Has any members tried, or heard of these Regina brand chain, and if so, how do they compare to the D I D , and EK.
I would wait for a brand you know, a broken chain can cause alot of damage and it could hurt you when i comes off.
I think regina is the same as EK. DID is also somehow affiliated with the two.
A quick search showed that this chain has a tensile strength of 9330 lbs. Your call if you think that is enough..
FYI, a DID ZVM 530 chain is at 10,370 lbs.
<!--EDIT|BusainSD
Reason for Edit: None given...|1151076209 -->
