changing brake pad
busastalker05
i jsut changed my brake pads and everything seems to work, just curious on how freely should the front wheel spin? super easy or ???? :bowdown::bowdown:
They will adjust after your first ride, so long as one of the pistons isn't binding. If you can move it at all with your hand, your fine.
Make sure you bed them in correctly.
Someone on here will chime in with the bed-in directions.
Some rolling resistance is normal for new pads. 'Bedding' them in is no more than routine use for about ahundred miles or so. No panic stops or rubbing/dragging the pads against the rotors as you ride.
