03TBUSA
Ok so I'm changing the rotors this weekend. Just wanted to post the steps before I start in case I'm missing something, you guys can help out.
1) pull calipers and front fender
2) loose 2 sm screws on right side
along with axle with hex tool
3) loosen left side 2 sm screws
4) hold wheel up and pull axle out
remove wheel
5) replace rotors to torque specks
6) put everything back together
Just wanted to make sure I'm doing this right. I know I need to grease the axle but not sure how much grease and what type of grease to use. Any help or if you see I'm missing something, I would appreciate.
Thanks guys
remove wheel
Thanks guys
