renaldoaoa
K,
Just changed my oil and I'm now looking at tackling the coolant.
The parts guy at my local store told me just to loosen the drain plug and it should suck out everything in my system including the overflow. The problem Im having is actually finding the drain plug on the system.
Looking at it closer I see theres the big radiator on top (looks to be for engine) and a lower one (I'm guessing transmission) but I dont see anything in a drain plug on either of them.
At the moment all I guess to do is just loosen the lower line comming off the upper raditor and let it drain that way, but I figure theres something else to it.
How exactly would I got about draining my fluild so that I refill??
Also when I find out how to get it out, I run it to operating temp with only distilled water/ cool down, empty then just add in the engine ice/water mix or should I do another flush with the water?
Thanks a whole heap!!!
