Changing Trans Gears
Spkrdctr
OK guys. I figure there are a lot of people on this web site that have contacts at some major shops for the Hayabusa engine. Anyone know if you can get different gear ratios for the trans? Specifically, a 6th gear that drops the rpm a good bit? Also, if anyone does this, what would it cost?Thanks for your help!
I don't want to screw your thread but most people do this with a sprocket(s) change.
There are some custom gear ratios for 5th and 6th. I believe Robinson builds them. Schnitz sells them.
