cheap power
lot boy
i was thinking how cool would it be if some 1 posted a pc3 map for a busa with a tre, bmc , and "gutted" stock cans
i figure you could make your tre and rework your stock exhaust- so you would actually only be buying a bmc filter and a pc3-
im currious if this settup would be worth the trouble?
if i had a dyno at my disposal i would research into this more and post it myself but....no luck there
sure it would be better to buy a full exhaust ect.. but some of us are doing good to get on the bike in the 1st place
thanks in advance for any replies
Gutting the cans will only make it LOUDER....with this mod and a PC, you could pick up 1-3 HP. The main restriction in the exhaust system is the header itself.
With a full system,PC,and a custom map you can pick up 10-15 HP and save 15+ lbs.
If some one did post a Map for those mods, it's only a starting point. Every bike is a little different and should have a custom map
And what's a TRE
With a custom map there is no need for a TRE....unless you are trying to do 200 MPH.
What he ^ said. NJ.
if i can gain 10-15 hp with full system than how much with slip-ons? and with slip-ons do i need a pc3?
Slip ons would be similar to gutting the stock cans, only a few hp gain, restriction at the head is still there. You may save a few pounds.
Slip ons are not going to add any noticeable HP gain 1-3 at best. They will sound better and you will lose money on them when you resell them and buy the full system that you should have bought in the first place
10-15 with a PC,custom map....slip ons 1-3....you won't need a PC, but it will run smoother with one.
You're right on-point with that BABUSA. I went through this trauma myself...
but now I'm happy with my full Micron race exhaust.
Thanks BA
Sorry to hear that you aren't going to make it this year to Laguna.
Rich (BA)
