found this post by Semi in an old thread but doesn't show c34 or c35 codes. but would look like the other two injectors from looking at the list...
i think this is the right list:
c00 none
c12 crankshaft positions sensor, pickup coil signal, signal generator
c13 intake air pressure sensor #2, for front cylinder
c14 throttle position sensor
c15 engine coolant temp sensor
c17 intake air pressure sensor #1 for rear cylinder
c21 intake air temp sensor
c23 tip over sensor
c24 ignition signal, coil #1 for rear cylinder
c25 ignition signal, coil #2 for front cylinder
c28 secondary throttle valve actuator
c29 secondary throttle valve position sensor
c31 gear position signal switch
c32 injector signal #1 for rear cylinder
c33 injector signal #2 for front cylinder
c41 fuel pump control system, fuel pump, fuel pump relay
c42 ignition switch signal, anti theft
c44 heated oxygen sensor
c49 pair control solenoid valve
