Clear Clutch Mod
BigSimp
Does anyone have any info on cuting the lower after you have done the clear clutch mod.
take the fairing off, take the center piece out of the factory clutch cover. set the fairing back on, dont bolt it, just put it into place. lay the derby that you just took off on the fairing directley over the clucth cover just like it should be. take a sharpie and draw around it. it will only be a half circle since part of the derby will be stick off the fairing to the left. take a dremel and follow around that line. you might want to make it bigger after the cut, just put the plate back on and move it over, draw around it a bit and cut. go to the hardware store get some door molding for 5 bucks and place it around the cut.
and your done.
Only thing I would add is you might want to put some tape over the fairing in the area of the clutch cover first.
no trying to thread jack
but what do used to seal the cover when u install the clear clutch cover
Thanks for the info pusher,since I will be send my clutch out to you for the mod, will you be sending the center piece back with it.
