clear front signals
kb97
i know i have seen this posted before but i just wanted to put it out there again: clear alternative lenses suck!!! i ordered clear lenses not realizing the company i ordered from was distributing that brand anyhow the lense housing fit is crappy and the bulb sockets did not want to fit into the new housing. the diameter of the hole that accepts the socket was to small!!! i had to shave the hole with an exacto knife which caused plastic bits to fall into the lense housing. so here i am trying to get these shavings out of the housing thinking to myself these f ing things are new i should not have to modify them!!!! WHAT CRAP!!!! in this pic if you look at the bottom of the lense and up the left hand side you can see the gap. i know the pic isn't the best but you get the idea
<!--EDIT|kb97
Reason for Edit: "bad spelling"|1073881943 -->
not all of the lens are bad... mine fit just fine. ( and I'm am very particular of my things! )
yes; I will agree, they could be made better. but I have not had any problems out of mine.
