Clunking noise
smedly
Yesterday I noticed a noticeable "clunking" noise when I move the handle bars left . Sounds almost like a ball in rolling in a container if that helps . Today I removed the steering damper and checked again and the noise is still there . Can anyone point me in the right direction as to what the noise might be .
Thanks!!
Are all the bolts tight on the front end...axel, calipers, fork keeper bolts on the triple trees...these shouldn't come loose but it is worth a look...possible wheel bearings? Just a few cheap things to check out.
Thanks for the help . It wound up being the horn . I guess last year when I had the bike apart putting on my Yoshimura 4-1 the bolts weren't quite tight enough . Over the past year they must've backed out enough that when I went over railroad tracks Thursday it just came off . Only the wires were holding it . Now I gotta find some bolts to secure it .
