So I took some time this weekend and took a few pics.
For you guys who are still running a stock clutch setup behind a strong motor you may want to look into this. In the past I've run heavy duty springs with my clutch. I never had a feailure but based on these pics I may have eventualy had a bad one. The next time you have your clutch out for PM you may want to pull the basket and inspect it very closely for any signs of wear.
Since my basket is apart it was easy to inspect things. You would have to look closely from the inside of the basket to check for any wear.
On the surface everything looks good:
