Hello Everyone,
I'm new to the forum , and was hoping some of you guys could help point me in the right direction on some clutch noise I'm having (introduction thread is here: https://www.hayabusa.org/forum/threads/new-busa-owner.189545/).
The bike is an '09. The guy I bought it from was convinced it had a spun bearing, but after looking in to it a little bit, I don't think that's the case. The bike sounds good sitting at idle, however, when you let out on the clutch - even in neutral - your hear a very audible "clunk-clunk-clunk." Once the bike picks up some RPM's it goes away, but I'm pretty sure that's just because everything else just drowns it out.
I changed the oil tonight and ran it through a paint strainer, which turned up just a TINY bit of metal shavings. Enough to concern me a little, but not what I would think a spun bearing would do.
Next, I pulled the entire clutch basket to see what I was working with. I thought I'd found my problem when I seen two needle bearings missing, but further research tells me this is normal:
Other than that, the only obvious things that stick out is a few knicks on the cushion springs (possibly where the shavings came from), and the fact that most of them are loose (they have play in their housings - some just a little, and one almost 1/8")....I've found mixed opinions of whether or not this is normal. Of all the springs, only one was tight in the housing, which is the one marked with tape:
One other noteworthy problem was the order in which everything came apart. According to the manual, the steel rings in the basket were supposed to be last, but I pulled it apart in the order shown in the pic, which puts the rings between the clutch discs. I guess I could have let them slip underneath, but I don't see how. Here's the pic:
FYI - I have spun the transmission shaft with a drill, and no noise was noted (I spun it pretty fast, and it was dead quiet), which is another reason I believe it has something to do with the clutch basket.
Any help is appreciated, and thanks to everyone!
-Nick
-Nick
